2 remove the bottom part u have a 10 mm screw that u have 2 take out its like in the middle of the seat and the part that folds down. put ur hand in there and move back and forth till u find it. just remove that bolt and the can pull ur bottom seat out.
If you take out the upper part first its easier. You need to fold it down and then you will be able to see bolts near the hinges. take out those bolts and the back will come out and then you will be able to see the bolt you need to take out for the bottom part. Its not very hard to do.
2 able 2 get the folding parts off u need 2 remove the bottom part first. the bolts for it are under the bottom. now once u remove the bottom then u can c what bolts hold the top. not very hard. just stick ur hand in there and feel for it.
