i want to make fiberglass door panels but dont know where to start...can anyone help me out by telling me what i need and if possible, a list of instructions on how to do this? thanks
well you need to have a base (chicken wire works) or a mold (if your going to make it exactly the same as your stock ones), yu need the fibre glass kit (comes with the resin, hardener and cloths) you need sandpaper, paint, and a mask, (so you dont get high lol) and a well ventilated place to do itMEMBER'S RIDE
i was driving along today and the check engine light came on.
i pulled over and looked under the hood.
the engine was still there...
...silly light!
hey punx i was thinking of making a fiberglass box during the winter for 12" subs and i was gonna make the frame from wood, and ten use (dont laugh) pantyhose as the base, and then spray tones of fiberglass on it. i saw something like thats some guy made his box like that and it came out good. and then i can prep and paint it up real nice....
does anyone have the instructions on how to do this? im planning on getting a door panel from the junk yard to work on and see if i could do this myself...is it hard to do?
Originally posted by fizzbob7first off, don't be a sissy bitch.....that's what you're beingOriginally posted by ACC0RD22no need to get sand in your vagina over this guys.
here's what i was wondering, if i were to have the same style as the oem door panels, should i just mold the chicken wire in to that taking into account the holes for the door handle and windows? i was also thinking about doing this to the ceiling and the sliding shade for the sun roof...bu it'll stop at that not like the red cd5 somebody posted on this site...too much fiberglass and too much red
well, i got an extra set of door panels and some chicken wire and i could get the fiberglass mats and resin from home depot. now where do i get sheets of pantyhose? this is my plan, mold the chicken wire and drape the pantyhose or other type of material to hold the first layer of resin and then the first later of fiberglass. is this the right method? should i use pantyhose or something else?
yeah, use fleece. Just go to your local fabric store, there will be plenty to choose from.
And yeah, just put the chicken wire frame down, and put the fabric over top. Then dab the fiberglass resin on there w/a short brushed paint brush. Do that until the fabric is soaked(turns dark) When that dries, it will be hard as hell. Then you can sand it, clean it, and apply some layers of fiberglass. I am also going to be doing this soon, or ...maybe not so soon since i wont have time up in college. Looks like a summer plan.
after i sand it and clean the fleece, i add a layer of resin and then a layer of fiberglas right? how many layers of fiberglas should i add? im thinking 4?
Fiberglass is a bitch to work with and hard to get to the exact mold you're looking for. Good luck though, hope it works out if you glass your panels.Adam - Retired OG member from '03
Your going to put down the fleece, then saturate it in the resin.. Wait till that dries, and it will be pretty solid. Then you can sand that down so its mostly smooth if you want to. Then just put the fiberglass on.
The best way i found is to have a piece of cardboard, and put the fiberglass cloth pieces on it. Then dab/brush them so they are covered w/ resin, but not too much. Then put those on the fleece and get them smooth. Make sure there are no air bubbles. You should be able to use 2 layers...3 at most, and it will be fine(you will prolly be able to stand on it) Then just sand that down real good, and fill in any holes w/bondo.
Fiberglass really isnt that hard, only problem i have is i always just use my hands, and say screw the gloves...I finally found some garage floor/engine degreaser that will take the resin off my hands
thanks for the help aero3685...btw, would the fiberglas mats and resin i find at home depot be good enough to do this? or is there somewhere else i could these materials from?
