Is it hard to install the emergency brake boot? And what else do you think is good for an interior upgrade? I'm new here so I don't know much about posting
shift boot and e-brake boot
are you talking about like the stock vinyl stuff? or doing a custom one?
I did mine recently, i just went to the local fabric store picked up like a half a yard of black leather (although you dont need that much) and just fabricated it, cut a hole, stuck it through the lever and glued the edges down to the base of the brake handle. Worked out nicely, i wish i had my other computer i i could take a pic and show you
the middle consoles themselves arent that hard to remove, just a few screws, but you hafta take off the piece around the shifter before you can remove the ebrake piece. Then if you want the new boot to look good, you probably would hafta change the ebrake handle cover as well. Only because the vinyl covering the handle is one piece , so in order to do mine i cut everything (btw, mine was glued in two places so it might take some arm muscle to remove) Its all kinda hard to explain but if you start messin around you will see it, its really easy. hope this helps
CB7tuner.com Appearance Specialist - PM me with any bodywork questions
sounds to me like this thread right here is up your alley.
there are alot of interiro upgrades you could go with...it just all depends on what your style is. first off, do you have a 5-speed or automatic? 5-speeds ofcourse have a larger amount of shift knobs readily available and rather cheap too...but auto's have a nice set of shift knobs also. i have an auto (for now) and i have a momo shift knob, momo e-brake handle, momo e-brake boot and just recently installed, a momo steering wheel ( i like my stuff to match so im going with an all momo interior). you could also take off your dash trim and paint it whatever color you want...there are so many things you could do to the interior that its not even funny... the only thing that holds you back is money.
Originally posted by fizzbob7first off, don't be a sissy bitch.....that's what you're beingSo. Cal OUTLAWZOriginally posted by ACC0RD22no need to get sand in your vagina over this guys.
