Shift Boot Question
    Shift Boot Question
    I wanna put a shift boot over the automatic shifter middle consol thingy what kind of boot would fit it?
    Bump!
    im sure any boot would do you just have to glue it down or use strips of velcro in case you want to take it off one day or double sided tape...oh, and make sure its loose enough to make all the changes down to D1
    Originally posted by fizzbob7
    Originally posted by ACC0RD22
    So. Cal OUTLAWZ
      theres been cheesier things done.
      Finally Up and Running. Numbers to Follow. Check my MR
        no, you wouldn't have to do all of that.
        you can remove the center console- there are a total of 6 screws:
        2 at the front
        2 in the center
        and 2 in the rear (behind the front seats).
        you'll find that the center console is actually two pieces.
        once you get the console off, that will leave the shifter exposed. you would then get whatever shift boot that fit (which is the hard problem) and slide it over.
        after that, you would put the center console back in place.
        as far as what shift boots will fit over an automatic shifter, extend all the way to the shift knob, and look good, i have no idea.
        best of luck in your endeavor if you decide to do it.
