ive been searchi and searching but cant seem to find anything on how to install GSR front lers onto our CBs any help would be greatly apprecited!!
Diy Gsr Front Leathers?
TYPE R Big Build thread 25,000+ VIEWS!!!http://www.cb7tuner.com/vbb/showthread.php?t=123069
I feel like BIG MEECH! LARRY HOOVER! whippin work! haileliuah one nation under god. REAL naggas gettin money from the freakin START!Tags: None
the 2 front seats
if the bracket line up then you should just be able to unbolt the accord seats then bolt in the GSR seats..
but i dont think they will match up
if thats the case you can either drill holes in your existing bracket to match the seats and bolt them in or replace the whole bracket and either weld in the bracket from the GSR or bolt it in where the existing bracket is
cut all the tabs off except the rear one closest to the middle of the car. put a bolt thru the remaining tab, position the seat so its straight, and put bolts thru the cut off tabs, secure them to the floor of the car, line them back up to the rails on the seat and weld them back on. takes about an hour with the right tools.
Yeah what he saidOriginally posted by LoDollar92LXcut all the tabs off except the rear one closest to the middle of the car. put a bolt thru the remaining tab, position the seat so its straight, and put bolts thru the cut off tabs, secure them to the floor of the car, line them back up to the rails on the seat and weld them back on. takes about an hour with the right tools.
Hustle Hard! This is a design of some gear I've been workin on.
