jdm armrest ?
Re: hmm
Originally posted by 4drcord
i thought people said the inspire was a 2 door accord? are you saying its a 2 door vigor?
Originally posted by usc
the inspire started out as a subset of the accord. but has long since branched off into it's own.
the states never got the accord-inspire version. by the time inspire came to its own, it came to the states as the vigor.
even now, the "inspire" in japan carries the same body as the usdm 7th gen acoord. but naturally the jdm accord = tsx.
89 inspire
the inspire is/was our acura vigor. however, i believe they still make the inspire, so...
a simple google search will yield you things such as:
translated from german: info here
another page here http://english.auto.vl.ru/catalog/ho...nspire/1989_9/
if you can read japanese: click here
interesting page comparing/contrasting the japanese/euro accord, accord euro r, american accord, and current inspire click here
current inspire:
Inspire
Inspire is sold in Japan only as a junior executive sedan. It is basically an American Accord but has a number of enhancement:
1. The 3.0 V6 produces slightly more power in Japanese tune (250hp, 218lbft). Besides, it has cylinder cut-off function to save fuel, similar to Mercedes' V8 and V12. When the car is cruising at leisure pace, the i-VTEC mechanism of one cylinder bank disconnects the rocker arms from cam lobes thus shuts off the valves. In this way, the V6 becomes effectively an inline-3-cylinder engine. This reduce pumping loss (the energy wasted to pump air into and out of the combustion chambers) and therefore save fuel. When the engine needs power, it will be reverted to 6-cylinder mode. The transition between 3 and 6 cylinders is so smooth that the driver will not aware.
2. To deal with the engine vibration generated in the 3-cylinder mode, the Inspire employs an active engine mount to compress and extend in sync to the vibration frequency.
3. To deal with the unrefined noise in 3-cylinder mode, Honda Inspire is the first production car employing active anti-noise control invented by Lotus in the 80s. The system uses microphones in the cabin to measure the engine noise and then reproduces an out-of-phase noise from loudspeakers to cancel the engine noise.
Originally posted by k-mart
i agree
a buddy of mine has a jdm accord armrest/center console that he picked up from ebay. a little pricey but adds a classy touch to his BBB...
I sold fizzbob that armrest
It wasn't jdm though but the jdm armrest was only for 90-91 accords anyways. They won't fit a 92-93. (console is wider) 92-93's had a builtin armrest in the drivers seat.
I saw a optional armrest for 90-93 integra that looks almost the same at my local junkyard. I experimented mounting it to a 4th gen but it wasn't tall enough to go over our console + the screw mounts were a little off.I need a custom turbo manifold built....
707 NorCal NinjaZ
Honda Twincam Motorwerkz?"I am the Yakuza CB7!"'92 Accord Sedan SiR
