Update: So far the only cutting needed is the back part of the housing. I cut to a seam visible in this picture:
Then I cut a slit to fit the ridge along the top of the projector. There's a "hinge" of sorts on the bottom portion of the projector to hold the bulb in place and has a screw. You'll need to sand/grind it down to be level with the head of the screw, and it should slide into the socket fine. After that, you'll need to place bolts to hold the projector in place, then put it all together.
I'll update with pics if I can get some soon.
