i bought a set of 1-piece black projectors about a year ago and they keep going through bulbs like nobody's business and its starting to piss me off. my stock headlights had the same bulbs for more than 4 years and these have gone through 4 differant sets of bulbs so far. when i take the bulb out, the filament inside looks fine but the base of the bulb looks burnt, like if it was under extreme heat. what could i do to fix this problem? would i have this problem if i got an hid kit? also, the new headlights use h3 bulbs instead of the stock ones. any help would be appreciated.
bulbs burn out
how is the seal of the housings, do u see any gaps? perhaps it keeps getting dirt in there..
umm what brand are u using, this time put some alcahol on ur bulbs to clean off any crap and check to see if their may be a leak.
maybe u got a shitty batch...are those bulbs u went through the same brand?
wait u said they use h3? is ur car wired for a h3? those are higher wattage i think...id have to check up on that...What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Re: bulbs burn out
Originally posted by arrozburner
i bought a set of 1-piece black projectors about a year ago and they keep going through bulbs like nobody's business and its starting to piss me off. my stock headlights had the same bulbs for more than 4 years and these have gone through 4 differant sets of bulbs so far. when i take the bulb out, the filament inside looks fine but the base of the bulb looks burnt, like if it was under extreme heat. what could i do to fix this problem? would i have this problem if i got an hid kit? also, the new headlights use h3 bulbs instead of the stock ones. any help would be appreciated.Visit us at http://www.valleyspecialists.com for all of your Honda and Acura service needs!
HEy i had the same problem with my one piece projectors!! they keept making fun of my at the auto parts store, cause i would come in every month or so.... and then one day when i was changing of the bulbs i noticed that one of the wires that comes out of the bulb and connects to the projector or whatever, was missing the little rubber/plastic piece, and it would ground out on the wires on the back of the projector....so i put some black tape on it and VUALA! havent had a broken bulbs since last january....maybe thats your problem?H22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
I as well have had the same probs with my 1 piece projectors and havent solved the prob but is pissing me off, have seen the prob on friends ludes and civics with one pices as well. when i get home i will try to see if there are any wires out anywhere and i will drill a slight hole to see if that is it , but im a little worried about that hole.. can much moisture still get in??
thanks
j
if u make a hole u can get a "L shaped" rubber tube and stick it in there faceing down just like OEM headlights, moisture gets out...not in..What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
im going to see if i could finally fix this by doing some DIY work. im going to drill 2 holes, one on top and one on the bottom. im going to connect a hose to the bottom hole and run it to the front of the car to get cold air into the housing and cool the bulb down...excess air will go out of the top hole. hopefully this works if there's anything i should worry about let me know.
Originally posted by fizzbob7first off, don't be a sissy bitch.....that's what you're beingOriginally posted by ACC0RD22no need to get sand in your vagina over this guys.
