HID Retrofit Project
    This weekend it looks like im going to try the projector retrofit that a few others of your have already done. So far I have:
    APC Projector headlights
    Valeo H7 D2S ECE Projectors
    D2S 4300 Orsam Bulbs
    Philips HID Kit
    What else do I need to complete the project ahead of me. Also i have a question about adjusting the headlights or projectors. One of you talked about adjusting the shield but I have no clue about that at all or any way to adjust the beam except for adjusting the entire headlight itself. Any help would be greatly appreciated, if not i guess its a guess and check thing. Thanks
    1991 Black Accord Coupe
    Sprint Lowering Springs
    Neuspeed/Koni Sport Shocks
    Suspension Techniques Front and Rear Sway Bar
    17" Motegi DP6 with Bridgestone Potenzas
    TSX HID Retrofit with 4300K Bulbs
    http://www.cardomain.com/id/sthrnba711
    www.hidplanet.com has all your answers
    www.maketradefair.com
      Philips HID Kit
      Glad to see you went with the ECEs As far as what else you need, an oven, time and patients. You adjust just like you would your regular headlight. About adusting the shield, it's all about getting the color you want on the cut-off. If you bend the shield just a little towards the inside, the side of the bulb, you'll get a nice crisp blue.
      05' S2000 GrandPrix White
      93' Accord (Sold )
      JDM H22
      Port n Polished Int Mani
      Bored TB, maxed
      MSD 6A
      I/H/E
      no cat
        Sounds good. Hopefull it shouldnt take that long. Also there are only two mounting holes and what should i use to hold the projector in(will the original screws fit).
        Did you guys with valeo projectors bend the shield at all for more color at the cutoff line? If so how much do you bend it or should i not worry about it and just leave them how i got them.
            Site doesnt work.
            To-Do List for Today
            Be Awesome
              Yes the site works but it is hard to find out exactly what to do for our model cars. I know a few of you have done this project with the exact same products so it would be great if I didnt have to go search another forum for answers that arent to my car. Thanks
                If you can wait til friday, I'll have a detailed picture DIY for retrofitting Acura TSX projectors in jdm one pieces
                My members ride thread
                  Yeah i can wait. This is my labor day weekend project. That way I can take my time and make sure its 100%.
                    yup, original screws. i used some strong adhesive to hold the projector down tight
                    93' Accord (Sold )
                    JDM H22
                    Bored TB, maxed
                    MSD 6A
                    I/H/E
                    no cat
                      When you did your retrofit, did you bend the shield at all or did you leave it stock? I really dont want to do anything i dont need to for fear of breaking them and having to buy new ones.
                        i left them stock b/c i forgot to bend them. but the valeos are pretty tough, so just go little by little. do you have a battery booster pack?
                        93' Accord (Sold )
                        JDM H22
                        Bored TB, maxed
                        MSD 6A
                        I/H/E
                        no cat
                          I was looking at other APC Housing projector retrofits and saw in the pic that the cut off shroud was on the bottom. On my valeo's the shield is on the top. Didnt know if i was mounting it upside down. The two mounting holes are on the top and so is the cutoff. Is this right?
                            http://www.cb7tuner.com/vbb/showthre...441#post340441
                              I have done the retrofit and its awesome. I have fun into a problem with one of them though cause the cut off is messed up. Its the passenger headlight and if you look at the picture you can see that there is a spot above the cutoff on the left side of the picture. Anyone know how to fix this or what could be causing it.
