hid bulb question
    hid bulb question
    i have an hid kit on my stock headlights right now and i was thinking about getting some jdm one-pieces...i was wonderin if it was as simple as changing the bulbs in order to make my hid kit work on the one-pieces or do i have to get a whole new kit? thanks
    Originally posted by fizzbob7
    Originally posted by ACC0RD22
    So. Cal OUTLAWZ
    anyone?
    So. Cal OUTLAWZ
      Switch out the bulbs. You're going from a 9006 to an H4, should be an easy swap I think.
      1992 Accord LX - SOLD
        Yup it is just that easy. Just make sure you get the correct bulbs that match the hid kit application you have i.e. the connections match.
        "This is a jaded bunch. To gain notice, you have to challenge conventional wisdom, test assumptions, and ignore the naysayers."
        FS Part out thread koni/skunk2 suspension, jdm pole, HID retrofit, Tanabe exhaust
          you will need to get H4 bulbs from your kit. they should be universal as far as the connector to the ballasts are concerned. you cannot use your 9006-type HID bulbs inside the H4 jdm housings without some custom work and without shielding the lower half of the jdm lense. the H4-type HID bulb should already have this shield. good luck ramiro !
          1cor10:31
          - 92 LX coupe
          - 96 EX wagon (sold)
            cool, i have the catz hid kit so all i would need is the h4 bulb from catz? or from any company will do?
            So. Cal OUTLAWZ
              It would be best to get it from the same company as your kit since you will know the connections are correct. Your alternative is as I mentioned above, find a bulb with the exact same connections and it will work as well.
              Also, post pics of this Catz kit's lighting. I have heard different reviews on it but have never seen any lighting pics.
                alright, i'll post pics up when i remember to take some at night...i ave to buy some 1-pieces first
                So. Cal OUTLAWZ
                  will the H4 shield work for the 9006 OEM housing? Just curious...since i saw the h4 shield that will fit the JDM onepieces to fix the extra glare.
                  My CB For Sale
                    Nope it will only fit on the jdm headlights or any other headlight that use an h4 bulb.
                      well I cant seem to find anything for the 9006, I've seen people make them but Im not bold enough to mess around with a HID bulb to make a shield for it since they are so expensive.
                      My CB For Sale
                        you just need new bulbs that match your headlights and you can use the rest of the hid kit you already have...i have the catz with 9006 bulbs and just bought some h4 bulbs for my one-pieces and they work perfectly...no need to buy a whole new kit
                        So. Cal OUTLAWZ
