amber lighting
    amber lighting
    i currently have hyper white bulbs in my amber corners. has anyone experimented using amber bulbs in amber corners vs. hyper whites. any PICS or INFO will be greatly appreciated!oh yea if so what amber bulbs do you use?
    JDMED
    buy my jdm part
    http://www.cb7tuner.com/vbb/showthread.php?p=544951#post544951
    I have amber bulbs in my amber lenses... there is little to no difference at all when you compare it against hyper white and amber lense.
      i have hiper whites, and i would actually reccomend them vs. the amber bulbs...
      i say this because, either way you are going to get amber colored lighting coming from the lense (since it is tinted w/ the amber). and the brightness of the hiper white bulbs will actually produce a little bit more of that amber lighting than the other bulbs will.
      when i'm driving.. anything next to me on the road.. whether it be a car, wall, or the road itself - lights up amber
      ... also, this way the amber lenses will also be more easily seen while the headlights are on.
      even if the bulbs are only a little bit brighter, every little bit helps.
