Just trying to find out which bulb gets a better use. It looks like the H1 bulb is a tad bit smaller than the H3, but i don't know if that's a factor. the reason i'm asking is because they are making projectors that take either h1 or h3 bulbs for the 4th gen accords. I’ve heard that the projectors suck for the 4th gen accords, but my question is in regards to the bulb itself. any info would be appreciated. thanks.
H1 or H3, which bulb is better?
thats like saying a 1156 bulb is Wayy different than a 168 wedge bulb.. They do the same thing.. ones brighter and a larger.. but i get what you said, over all tho the H1 isa better bulbOriginally posted by OM617
H1 and H3 bulbs are intended for different purposes so you shouldn't compare them against each other. H3 are only used as foglight bulbs, so they don't make a good headlight bulb.
correct me if im wrong but the h1 is like 1550 lumens
and the h3 is 1450 lumens
Retro!
Hater
For effective foglights, brightness is not the key factor
My response below assumes gnehc1 is interested in effective foglights, not trying to turn foglights or something else that uses the H3 into driving lights for example.
Well, not for foglights it isn't. The axial filament is precisely why H3 bulbs are used for foglights. Foglights, to be effective for seeing in foggy conditions, should never project a high vertical beam --- that would only light up the water in the air.Originally posted by xplode..... its the worst way to have a beam pattern,
As an exaggerated example, consider what happens when you use highbeams in snow or fog: it makes seeing worse and makes it look as if there is suddenly MORE fog outside.
Very near the ground, there will be less fog hovering --- that's why fogs are mounted low, and also why they spread light horizontally and don't light up hardly any above bumper height.
Once you get a foot or so higher, there's more fog (i.e. water) in the air --- the idea with foglights is actually to try and light the area below where the water in the air is, not to power through it with a bright light (which can't work)>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
