crackle in speakers
    crackle in speakers
    when im driving and i hit 75mph my rear soeakers start making a weird crakling sound...and its loud! i think it comes from the passenger side but its really loud and stops when i pass 80 mph...what the hell is up with that? any help would be greatly appreciated...oh, and where can i find an internal anntenna relatively cheap?
    Originally posted by fizzbob7
    Originally posted by ACC0RD22
    So. Cal OUTLAWZ
    Could possibly be engine interfearence or a wire thats getting shorted. I would check the wire and make sure everything is tight and on there.
      If you're using the stock wiring, most likely it's breaking down. You're probably hitting the right combination of noise level and vibration to hear it at 75.
      As far as the antenna, I personally have had no luck with aftermarket internal antennas. If you're replacing the stock one, I would seriously consider repairing it. Parts can be had off eGay for cheap.
      Bart: What's your name?
      Jim: Well, my name is Jim, but most people call me... Jim.
        Maybe try hooking a noise filter (cant remember the fancy name for it) to you amp or to your battery terminal. This should stop any unwanted noises if it indeed is coming from an alternator or somewhere in the electrical system. Also most amps have these built in so you may already have this covered. I don't know if you are runing an amp or complete stock system.
          Do not use a noise filter!
          Sorry.
          They eliminate electrical by apply filters to cut off certain frequencies. It will totally screw up your sound.
            i dont know about screwing up sound, but i still dont know if hes stock or amp setup.
            If amp setup the amps most likely have them anyhow.
            If stock i haven't personally ever installed one to a stock setup but have seen it done and the system sounded great still
              it wont screw sound, it will just limit how much goes through, i think it takes about 20 watts out of the entire system.
              what is your setup? if u have a amp how and where are your rca and power wires run to?
              Retro!
              Hater
                oops, sorry for not stating my setup...right now i have stock speakers up front and pioneer 3-way (i believe) speakers in the rear with the stock wiring...i just cut and spliced them together. the speakers are about 1-2 years old.
                So. Cal OUTLAWZ
                  well throw out everyones ideas now haha
                  well humm im not sure, do u hear it in all speakers or just one?
                  maybe its a grounding issue...but most likely no biggie...stop speeding lol
                  Retro!
                  Hater
                    Originally posted by accordztech
                    stop speeding lol
                    YES MOTHER!!! sheesh
                    but actually thats whats keeping me from speeding and its annoying. it souds like its only coming from the passenger side but its soo loud its hard to tell...as for a grounding issue, i just connected both wires from the speaker to both wires from the car...i figured grounding took care of it self since i had no extra wires
                    So. Cal OUTLAWZ
