Run power from the battery to a distribution block, run your remote wire from your deck to 1 amp, from that amp, run another piece of remote wire to the other amp. For the ground, get a grounding block that'll handle 2 amplifiers, ground it to the body, run those grounds to the amps. Run rca's from your head unit to the back, 1, 4 channel pair, 1, 2 channel pair.
I almost forgot, run your power and remote wire on the same side, run your rca's on the opposite side, to eliminate possible alternator whine
my other question is, what do you do with the stock speaker wiring before wiring up the stereo, bc i was told to bridge them back or something like that bc i know your not suppose to use your stereo wires if your running two amps
wtf ever you can use your factory wire unless gonna run seprates up front. unless your going for a WORLD SQ CHAMP setup there is no prob using your factory wire.
Members Ride sold...
first off where did u ground the amp? second is your rcas separate from power wire?
where's a good spot to ground your amps, i realize that when my voice amp is hooked up and i go to hook up my rca's to my bass amp it's starts to make that buzzing noise thru all the voice speakers as well as the bass speaker
anyways this is how i have my set up one power cable running from the battery to the bass amp then it's split to the voice amp same with the remote wire also with the ground's,
the best ground is to take some sand paper and get to bare shiny metal. you wont have grounding issues then. DO NOT USE A SEAT BOLT. try that for your grounds and see if that gets rid of your "buzzing". if it doesnt stop come back and let us know.
