i have a 1 farad digital capacitor i wired it through positive and neg speaker wire i plan on using it as a backup battery for my alarm..i wired it it turned on and jumped to 12.2 and i watched as it died out at like 6 after i disconnected the positve and negative from the battery terminals...does this mean its good
How to check if a capacitor is working?
TYPE R Big Build thread 25,000+ VIEWS!!!http://www.cb7tuner.com/vbb/showthread.php?t=123069
I feel like BIG MEECH! LARRY HOOVER! whippin work! haileliuah one nation under god. REAL naggas gettin money from the freakin START!Tags: None
[QUOTE= And I don't understand what you mean when you said you hooked it up with speaker wire?[/QUOTE]
i took 2 speaker wires 1 from the positive terminal to Positive on car battery
1 from negative to negative on car battery
turned on fine and read 12.5 and when it urned the car on went to 14.5
when i take it off the car battery it drops down and dies at 7 in about 2 minutes
Originally posted by sonikaccord View PostCaps aren't batteries. It isn't designed for that purpose.
ok..i know that. but i got the cap for free and my cousin has a 1 farad cap that keeps his alarm running for about another 10 minutes after is battery is pulled..so im looking to do the same thing.
wtf why????? u know they make battery backups for alarms lolOriginally posted by Clean-CB7 View Postok..i know that. but i got the cap for free and my cousin has a 1 farad cap that keeps his alarm running for about another 10 minutes after is battery is pulled..so im looking to do the same thing.
Originally posted by Clean-CB7 View Posti have a 1 farad digital capacitor i wired it through positive and neg speaker wire i plan on using it as a backup battery for my alarm..i wired it it turned on and jumped to 12.2 and i watched as it died out at like 6 after i disconnected the positve and negative from the battery terminals...does this mean its good
your silly man, why not go spend 15$ on a backup battery for your alarm capacitors arn't for that.
you are silly.
On a side note, all capacitors are virtually useless, unless you have an upgraded alternator and upgraded wiring ("the big three").
-mak
Bought From: MadSpleen85, jimy, CB7_ACCORD (kouzie), Chrisfrom1986
Sold To: vinbon63, chessboxer, darkfusion42, LowNknoxville, bowzil, 1993hAccord, mcdizzle, 93accordfreak, lilb_1979, rocketman_471, Bad_dude
Traded With: cb95spd, chessboxer, sohc em
[ Completed | Pending ]
Originally posted by Maple50175 View Postyour silly man, why not go spend 15$ on a backup battery for your alarm capacitors arn't for that.
you are silly.
this is not a normal maple post
Originally posted by mak View PostOn a side note, all capacitors are virtually useless, unless you have an upgraded alternator and upgraded wiring ("the big three").
-mak
how do you know this?
Maple50175 - you're annoying =P
Brandoncb7 - I don't mean to come across like an ass but I see why you irritate Aaron now.
JoshM - Crotch rocket = chick magnet.
you are silly.
and where did you see them for 15$ in boston?? if that was the case i would have been bought one.
???? why would you want your alarm to only work for 10min past after you take your battery out. if someone was going to break in your car i'm pretty sure it would be well after 10 mins
i agree with some of the other comments, go get a battery back up for your alarm and be done with it. it sounds like your cap is doing what its suppose to.
oh yea using speaker wirer to run battery voltage. BIG
Last edited by jc32; 12-28-2008, 06:22 PM.Do not be the lonely nail sticking out, for I will be the hammer that puts you back in your place.
not in boston but search ebay for a dei 520t, several on there for less than $15 shippedOriginally posted by Clean-CB7 View Postand where did you see them for 15$ in boston?? if that was the case i would have been bought one.
your cap seams to be working like it should, it is not designed to be used as a battery.FA1
355
