Hey, I've been searching for this module. People said that eBay had it, but they don't now. Is there anyone out there who will know where I can get this module from?
Insight DRL module
they have been discontinued for a couple years now...
honestly the way i had em hooked up was almost full power lol. run a relay setup and then probably a resistor inline to knock down the power and call it a day.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
I was thinking of doing that. What resistor and what relay can I use?Originally posted by accordztech View Posthonestly the way i had em hooked up was almost full power lol. run a relay setup and then probably a resistor inline to knock down the power and call it a day.
Thanks. Is there a way that I can go to Honda and get one from them?Originally posted by JaK FRoSTWhiTE View PostNot sure if there is another brand out there.
I bought mine in 2004. It was hard finding it then, imagine now.
its not an oem part its aftermarket.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
So, that means I won't be able to do it?Originally posted by JaK FRoSTWhiTE View PostAnd it was only standard in Canada.
Even with that, it was built into left side wiring harness.
Controlled by a relay under the dash.
is it hard to install DRLs
