Tapping into sunroof wiring
    SO I'm looking for a good spot to tap into my dash wiring for all my accessories, such as neon light's and such.
    I was behind the cruise switch and saw there is a second plug which I can only assume is for the sunroof which I don't have.
    Sooo? Can I tap into that for power, accessory, and ground?
    If so does anyone know which is which?
    Why not just run some wires to the fuse panel? That way you have the protection of a fuse?
    But if you really want to use one of those plugs, you'd obviously use the one that's not being used by the cruise. What I'd do is use a test light to see if the unused plug has power with the key on or off, if it has power with the key on, there is the 12v wire, the other should be a ground.
    I'm sure the reason there are 2 plugs is because, they just used a "universal" harness for those things, rather than have to separate which ones go for the ex models and which ones go for the lx models.
    Does that make any sense? reading that kinda hurts my head
      all ur going to find in the sunroof switch is ground, 2 output negitives ground and a parking light wire.
      Go somewhere else like the fuse box.
      Retro!
      Hater
        Exactly, there are already accessory power taps on the fuse box for that purpose.
        1992 Accord Wagon (RETIRED)
          Yeah I was thinking about that but as much wiring as i've done in my life both stereo and other I've never wired to the fuse box and am unsure how to.
          Wanna give me some pointers.
            Why would there be a parking light wire in the sunroof switch?
              Wiring your head unit is simple. For the yellow wire on the stereo, find a fuse that has 12v all the time, whether the key is on or off. That wire stores your memory, radio settings, etc.
              As for the red wire, find a fuse that has 12v with the key on, like the radio fuse.
              Then the black wire, just find a screw or something behind the stereo to mount that to, and you're golden.
                Sorry i must have been confusing I know how to do stereo wiring I've done probably 100 of them. I was asking about wiring to the fuse box I know nothing about it.
                  It's a quick disconnect tab that provides a constant 12v. All you need is the female connector. It's the one closest to the ignition harness
                  YouTube Clicky!!
                    isnt there a light that lights up the switch?...yeup
                    Retro!
                    Hater
