i will be getting the bumper wit the oem fog lights in it in a few days and i was wondering if i will need to get the wiring and switch or what ever ill need for it, let me know asap before i get it on friday, thanx
oem fog light wiring
it should be very easy to wire them up.. you just need to go thru the passenger side plug and get the switch into the dash and wire it up to the battery, i might be able to throw a diagram together but its not really neccesary unless your real new to wiring and what not but if you need one let me know i can see if i can get somthing for ya..
i just finished wiring up my foglights on my 92 ex. i got the complete set on ebay, so it came with all the wiring. i even got a hold of the factory installation instructions. with all the wiring, it was not too difficult. the most difficult part was cutting the bumper and reassembling/installing it. if you don't have all the wiring it may be difficult. i don't know if you have the switch or not either. all of the parts for the foglights have been discontinued so the dealer is no help. i'm sure you can rig something without all the wiring. if they are hooked up with all the wiring, they turn off automatically when the high beams are turned on. pretty cool but no big deal. if you got any questions, i'll try to help. i got the instructions faxed to me from a guy at hparts.com. he was a lot of help, but like i said without all the wiring, the instructions will be useless. anyways, good luck, they make the front of the car look even sweeter and they help a lot with visibility.
i don't have a schematic for the switch, but i just found the switch on ebay:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2445805753
good luck
i have the switchi think i goes next to the hazards and the rear defrost right? the bumper i have is the oem bumper wit the oem fog lights not a custom bumper. i need to know if i need to yank the wiring out of the car i got the bumper from or would it be easier if i just rewired it without the harness from the junkerR I P
91lx
gone, but not forgotten
www.team-integra.net
www.clubintegra.net
definitely, definitely, definitely get the wiring out of the car. it will make it much easier. there are 3 or 4 sets of wires and they are not integrated into the chassis wiring because these lights were only an accessory not an option. the first wire connects the two lights, has a ground attachment and connects to the next wire. the next wire runs from the bumper to the bottom of the fuse box in the engine compartment (you will need to remove the screws holding the fusebox down and lift it up. this is where i forget if there are 3 or 4 wires, but the next wire runs from the fuse box in the engine compartment thru the firewall to the fuse box inside the car. it may just be one wire that runs from the bumper to the inside of the car. then a wire runs from fusebox inside car to switch. there is a relay attached near the fuse box inside the car that is part of the wiring also. it kind of sounds complicated but it is fairly easy. you should not have to cut any wiring at all. everything plugs into factory plugs. i can double check my instructions tonight to see if it is 3 or 4 wires. good luck
