cd5 clock?
    cd5 clock?
    I was working on a cd5 accord today ('97 v6 sedan) and I noticed it had this clock and button set up. I'm wondering if this can be transplanted into our car where the three buttons (defog, hazard and foglight) are on the dash or if it has been done before.
    I'm gonna take the maplight, side markers, lip and this clock if this car gets junked soon
    Being normal is probably the lamest thing you can try to be
    It looks like it...there may need to be some glueing and body filling done
    YouTube Clicky!!
      It seems like you should be able to fit it with some precision cutting. But not if you do have the fog switch...
      Sold to: dbsharp, daheavyking X3
      Bought from:'93CB7Ex, xkjnboix, duffmanivxx, remix405, CB7tuner official shop
        No lol
        Its molded with the plastic of the bezel.
        Why would you even want that clock?
          where would ur foglight switch go then?
          [COLOR="Magenta"]
            even if it worked there's really not much u can do with the oem clock location so you would end up with 2 clocks...3 if your deck has a clock... unless you plan to put something else in the original spot. Either way the oem cb clock looks much better, and already has a spot cut out in the dash for it.
              Don't listen to these naysayers! If you like the idea, go for it.
              Worst possible outcome is you'll have to buy another dash bezel.
              You can cover up your stock clock with an Integra clock delete panel, or make your own delete panel. Or if you wanna run two clocks, power to you.
              My pictures/photos will return soon...
                Well my current clock won't stay set and all the fuses are replaced now but it still jumps around. I've heard that it just needs replaced so I would just make a delete panel out of whatever is lying around.
                There is a 95 accord v6 in remarkablely good condition but mechanically a wreck that I may get to pirate interior parts, side markers, front and rear lip, rims, rear mudflaps and maybe even as a bonus the oval shaped intake tube that will fit a k&n filter I have lying around.
                  If your clock is simply not working correctly I would just grab another clock from a junk yard unless you REALLY want this CD5 clock. I do like the location and it probably helps a bit with visibility in direct sunlight (If you drive with your headlights on during the day like I do) but if you just want your clock working, grab another. They pop in and out pretty easy and you dont have to fab up some method to get the CD5 clock in place.
                  Bought from Darkcloud
                  http://wheelflip.com/r/DrAkE
