Bass issues
    Wow I'm all sorts of confused I thought you were running one sub now I'm seeing your wires going into channel 3-4? Where's channel 1-2? Are you running 2 subs?
    That's a bad ground location try directly on the strut bolts not the strut bar and sand the paint off then put some die electric grease on there.....
    My 90 coupe Mr thread....
    http://www.cb7tuner.com/vbb/showthread.php?t=178452
      I think this is a 4 channel he's just using for his one sub alone. The 1-2 rcas aren't even plugged in, so that's what I'm assuming. I would REALLY like to see that input switch that is cut off in the pic.
        Originally posted by SPLCB7 View Post
        Mabe turn up your bass on your deck above 0?
        OK it sounds like your subs coil is burnt pull it out and look at it with a flash light and see if your coils burnt. If its not copper in color it's dark then you have burnt your coils ie. They're blown omost just a little more play and no more sub. I could be wrong so I would check. If you have tryed 2 different amps and got the same results its deff your subs or your RCA output on your deck. There's not many other reasons you wouldn't get sound.
        Well my bud and i just put my box in his 280z and its thumping to the max and it sounds awsome.Deff not the speaker.HE has the same deck and set up but his amp is a Lanzar vibe 420.I dont know what to do but take it to a shop and have it checked over
          I've asked this 3 times now, does your deck have sub control?
            Try channel 1/2 and change your grounding spot.....
              Wait this is a 4 channel amp and your rca's look like there on channel 3-4 try channel 1-2 and switch off channel 3-4 insted of having it on lowpass....
              This is a 4 channel amp . Only 3 and 4 is bridgeable and there is only one sub.I will Change the ground to the strut itself.I only have the 3 and 4 channels plugged in
                You shure? Most 4 channel amps are 2 separate boards. Can you take a pic of the other channels? I've never seen a amp set up like that its normally Chan 1-2 are bridgeable and 3-4 are bridgeable.....
                  I think the sub control/non fader is set too low, but I'm being ignored...
                    No your not bro. He's probably tryed it already...
                      Lol, I've asked him 3 times already....
                        I wrote earlier that my deck does NOT have a sub control
                        Ive changed the ground while i went out to take a pic.Im going to change the channels tomorrow because it just started pouring outside and i just slipped in dogshit and mud.im pissed off
                          Sorry I just went back and reread the posts, found it at the top of all your pics. Last thing to do is try a different set of RCAs.
                            This is my amp on the 1st and 2nd channel .The might be but the manual says to use 3&4
                              What is the "input" switch set to? And what are the options?
                                Its cool . I thank you and everybody who has helped me try to fix my issue.But the fact is its hard to do that when your not standing right in front of it.Again Thanks for the help!
