EX has 6x9's in the rear and 5" in the front doors.
LX has 5 1/4 in the rear and 6.5" in the front doors.
DX has the same as the LX.
Taking off your door panel, take the screw out of the door handle, pull the handle out, there's one behind it. There is one in the arm rest part of the door panel. Pull out so the clips pop out, disconnect the wires, and your panel is off.
Taking off your <a href="http://www.serverlogic3.com/lm/rtl3.asp?si=11&k=door%20panel" onmouseover="window.status='door panel'; return true;" onmouseout="window.status=''; return true;">door panel</a>, take the screw out of the door handle, pull the handle out, there's one behind it. There is one in the arm rest part of the door panel. Pull out so the clips pop out, disconnect the wires, and your panel is off.
If thats what Honda is saying (5 in front,6x9 in the back) or Crutchfield, then they're wrong. Or I have some kind of freak car. My rears are 5.25, and I'm assuming the fronts are as well.
How long is the door panel removal process? And can everything work without the panel? I think I'm gonna take off the panel today if I can get the weather to hold up, but I don't want to put it back on until I get the new speakers in...
