interior fusebox
    interior fusebox
    can someone show me a diagram or a pic the interior fusebox. ex. the proper amount of fuse in each slot, and what each one is.
    are u talking about the one inside the car by the hood release handle?
      For the interior one, under the driver seat, take off the cover and it should have the list. If you lost the cover, when I get home i can attempt to scan the cover on my computer I dont know it it will lay flat on my screen tho.
        for the inside this should be the line up with the fuses
        at the top closest to the door it goes
        [30A spare fuse][7.5A A/C clutch relay][7.5A starter signal][emptry][radio motor antenna]
        under that is
        [20A spare fuse][7.5A cruise control][7.5A r/c mirror sun roof relay p/w relay]
        [30A wiper washer][10A spart fuse]
        under that is
        [15A spare fuse][10A turn signals back up lights][15A ecu][emptry][7.5A spare fuse]
