Sugestions on Amp and wiring
    Im about 2 run 6, 6.5 " beyma speakers in my car how many amps should i run on. I have a wagon im putting 2 in front doors and across the back were cargo area is im going to mount 4 on a nice size of wood how many amps would your guys recommed me using what series and wattage amps would my generic tweeters sound ok with them of will i have to step those up give me sugestions
    i already told u man..
    http://www.get-gifts-for-free.com/?ref_id=4810
    1992 Honda Accord 4dr 5spd EX- R.I.P 8/10/05
      after reading ur post, i got lost, do u want to mount 6 amps in ur car?? or just 4??? how many amps do u want in ur car?
        Hahaha he was asking how many to us! Any ways you have to determine how many by the type and the number of channels you are going to need! I would suggest 1 channel per speaker then you say monoblock,two channel, four etc. If you run six speakers you want three on left side and three speakers on the right! So now you need to figure how much power each speaker needs! If you have tweets, are the stock accord tweets or some shitty ones from a bulk buy or what, I suggest matching speakers and or other components as much as possible but not always for everyone, If I were you I would mount the speaks 1 in each of the doors, one in custom kicks l/r and two in the rear l/r, as for tweeters if you like quality, go with those image dynamics horns that mount under the dash on either side! Those are awesome and sound insanely good! Are you gonna run filters or xovers to tweets?
        WaC!
          let me give you my setup as an example, i hope it helps.
          I have four midranges, Kenwoods (the doors and backpanel, i have a sedean) all running and bridged to a 2 channel 250 watt Sony amp.
          i have 2 tweeters mounted on the front pillars that are connected to the deck itself (connected as a front channel)
          I have 2 subs in the truck connected to a high power two channel low freq. amp.
          two amps total. Only speakers connected to the deck is the tweeters.
          twp amps, 6 speakers, one deck, two tweeters
          hope this helps
          Claire - '92 Mercedes-Benz 500E - AMG&Bilstein Treatment - The Wolf in Sheep's clothing.
          Alice - '97 BMW 540i6 - Dinan Tuned. - Low Profile Weekend Warrior.
          Felicia - '11 Ford Fusion - Luxury Package - Daily.. daily.. ugh.
          Originally posted by JoshM
          Okay to do: "I'm sorry I broke your mailbox, here's $100.
          NOT okay to do: "I'm sorry I fucked your sister, here's $100.
            I generally say 50 watts RMS per speaker. so, for 6 speakers, go with a 300 watt RMS setup.
            As far as wiring them up, it all depends. You need to get the resistances on the speakers. Most are 4 ohm, so you can get a 2 channel 300 watt rms amp, run three speakers off each channel in parallel, and you'll be good.... 2.66 ohms of resistance..
            --JDM F22A--
            JDM schmeDM, these lights are DIY-DM.
