help! white glow gauge accord cc1
    Hi,
    i have a problem with my new white glow gauges. I want to switch on the gauges over my headlight switch but it doesn't work. The control unit from the gauges have a extra switch. This switch needs one signal to work on and off.
    Now, my problem is to connect the headlight switch with the extra switch from the gauges.
    What do you do when you install the gauges?
    Can anybody help me?
    thanks for your support.
    It's all about 2f2f
    are those ur gauges? or are they a picture of the same kind u got?
      It's a picture of the same kind i got. The white glow gauges works but the connection to switch on/off is the problem.
      I don't like the extra switch from the gauges. It should work over the headlight switch.
      It's all about 2f2f
        i have the eurolite carbon glow gauges. and i hooked the power up to the dimmer switch on the right side of the steering wheel, get a test light and turn the headlights on and power will run to one of the wires i am, not to sure which wire it is i forget.
          I have the same problem. Currently I just have a positive wire I am hooking up everytime I drive at night, I need to get it fixed, I like the dimmer switch idea though
            red power wire on guages:
            the fuse box in the "drivers kick panel" has a tap in spot for the park. lights.
            remove fuse cover and right above the fuses theres a blade terminal, (4 total) recesed in squair holes..i think the 3rd one towards the front of the car is pk. lights
            test with meter for 12+ volts when pk. lights are on, and nothing when off..
            use a 10 amp. fuse to protect in line where you tap into the fuse box
            black wire
            -ground to bare metal
            you could always hide the guage switches under the dash, how often do you really change the brightness-color-whatever they do
            91 ex 1badwag
            91 lx wag (aka the beater)
            92 ex 4-door
            HONDA...its not just a way of life...its an ADDICTION!!!!!!!!!!!!
              usually i put it under the ignition area, that area under there..
              Retro!
              Hater
                @my92cb7
                best idea with the dimmer! It works! Thank you
                It's all about 2f2f
                  no problem!!! I was going to tell you about the fuse box area but i know they dont give that much wire so, I thought it would be better to keep every thing close together and not have a boundle of wires running all over the place. I am glad everything worked out good for you
