Help
    Help
    I need helop.. i just installed a cd player.. and took out my changer and stock radio.. well anyways whenever i start the car.. all the settings resets.. and the clock is always at 1:00 right after i start it.. if i was to change the clock it would work but right after that the car is shut off.. its back to 1:00
    theres 4 wires disconnected.. brown, orange, white.. and white with blue strip....(it was cut off the cd changer harness.. only way to get the harness apart from the CAR harness)
    i'll have pics later..
    http://www.get-gifts-for-free.com/?ref_id=4810
    1992 Honda Accord 4dr 5spd EX- R.I.P 8/10/05
    Sounds like the "constant hot" wire isn't connected. On most of the stereos I've installed, it was a yellow wire that went to a constant (unswitched) power source and that is what holds the memory. Is there a diagram on the top of the head unit that tells you what wires are supposed to be connected to? If you used an adapter harness, all of the wires are there.
    Originally posted by Junior Smurff
    Nevermind guys, google search works wonders!
    I don't have road rage, my car just goes faster than yours!
    Accords are for winners. And Grandmothers. But mostly winners.
    I have grown so Tired of Internet Illiteracy. Please learn proper spelling and grammar. For your sake and that of your children.
      yea the yellow wire... is fuckin up... its not connected.. the yellow wire on the harness ain't working.. so i took the yellow wire and hooked it to the yellow wire on the deck.. and also the red..idunno.. i have to look at it over..
      so the yellow wire controls the clock? when the car is off? it keeps resetting..
        if you are referring to the dash clock, no the yellow wire does NOT control that. the yellow wire controls the whole headunit. it should give it +12v constantly even when the car is off keeping the memory of the stations as well as the built in clock. wire that up correctly and you should solve your problem!
        1cor10:31
        - 92 LX coupe
        - 96 EX wagon (sold)
          could be memory wire? i dont really know
            well guys nevermind.. everything is all set... it was the radio back up fuse 7.5a that was blown.... therefore i couldn't get any memory for the stations and clock on my dash
            everyything is all set..
              this just happened to me my clock dont stay in memory
              it sets back to 1:00 all the time. HELP!!!!!!!!!!!
                I'd say check your fuses.
                '93 Bordeaux Red Pearl LX 5MT
                Prev CBs:
                -'93 BRP LX 4AT
                -'92 AGP LX 5MT
                -'93 AGP EX 4AT
                10yrs after my first cb, I'm still driving one!
                  yo remember when we checked to see if your radio worked and it didnt that yellow wire wasnt wired up it was probably that
                    Yeah thats what I think as well.
                    Prev CBs:
                    -'93 BRP LX 4AT
                    -'92 AGP LX 5MT
                    -'93 AGP EX 4AT
                      Yellow wire= constant power (memory wire) Hook that up and u should b str8
                      Check out what used to be mine
                      Click Here
