its for the 12v or ignition.... i think we had the red wire hooked up for 12v+ cuz it was always on... but the ignition wire doesn't work period.... and for some reason the cd player we were hooking up wouldn't work without the headlights on..... anybody know whats up?
white w/ yellow stripe wire?
Originally posted by 2.2litrebeateryou have something hooked up to the illumination wire. white with yellow should be constant, ignition should be yellow with red and ground is black.
nope.... doesn't work period...i got it from wagalude and he said it worked when he tested it.... is the ignition wire hooked to a fuse anywhere?
SOLD!
Originally posted by g-wagonnope.... doesn't work period...i got it from wagalude and he said it worked when he tested it.... is the ignition wire hooked to a fuse anywhere?
get a tester, you know those things with the sharp tip and a light at the end and ground it to the ground wire on the deck -best bet so you KNOW FOR A FACT YOU HAVE A GROUND-
strip the white w/ yellow stripe wire so you have enough copper to work with, be carefull not to cut it short or it will be a pain in the ass
with the tester connected to the stereo deck ground, prod or poke at the white w/ yellow stripe and see if it lights up
if it lights, might be a problem with your deck,
if it dont, could be a fuse...
post up results!
Claire - '92 Mercedes-Benz 500E - AMG&Bilstein Treatment - The Wolf in Sheep's clothing.
Alice - '97 BMW 540i6 - Dinan Tuned. - Low Profile Weekend Warrior.
Felicia - '11 Ford Fusion - Luxury Package - Daily.. daily.. ugh.
Originally posted by JoshMOkay to do: "I'm sorry I broke your mailbox, here's $100.
NOT okay to do: "I'm sorry I fucked your sister, here's $100.
