i having a little problem i just installed underbody lights they work and all i hooked them to the radio ground and 12+ wires, but now when i tried to unlock my doors wit my alarm pad the alarm goes off but the locks dont pop up. the locks also dont pop up when i take the key out the ign. when i lock the doors they go down, also the switch makes them go up and down i dont no what the problem is
lock problem
What 12 volt wire did you hook it up to?
Your best bet when adding lights like those is to go directly off the battery. That way your not tapping into any OEM wiring. It will be completly seperate from the vehicle wiring. Make sure you fuse it so as not to burn up any wiring. For ground, you can either make a new one or use a factory ground. Just stay away from grounding it to the negative terminal on the battery.
