cigarrett lighter fuse
    my lighter isnt working and i have a beltronic accelerometer plug into it..so therefor i want it working! where is the fuse for it or does anyone else have any idea what it could be?
    Check Out My Car
    I have the same problem, wanna get it fixed eventually..
    1993 Cobalt Blue Accord EX - Sold as of December, 2009
      i know it pissing me off and i want it working!
      Check Out My Car
        it would be in the fuse box, labled on the lid i think its in the under hood one.
        FA1
        355
          x2
          "form follows function."
          Louis Sullivan
            I believe the cigarret lighter fuse is the same one as the radio ignition one, check all the fuses in the kick panel. -damien
              its in the engine bay.
              i bet the interior light doesnt work either right?
              check the fuses in the engine bay.
              Retro!
              Hater
                get a haynes manual it tells u everything that everything is tied into what fuses goes with which elctrical thing ether that check to see if the connector slipped off u u have messed with the dash took it apart ?
                (\__/)
                (O.o )
                (> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination!
                  The ground connect on a black wire could have come loose. Or, if you pull out your radio you can see a little plug thing that snaps/plugs into the back. Either that's not in so it's not making a good connection or, what happend to me, the solder joint actually came undone in that little plastic plug. I had to resolder it. Something isn't making a complete eletrical connection. And if that's the only thing not working this would make sense rather than a fuse.
                  Metal Metal and more Metal!!!
                  How much does your wheel/tire combo weigh? Post here!
                  -=Suicide Crew Member #1 (only member so far)=-
                  MY RIDE
                  "I was hoping the Wolverine would finger one of those Japanese girls and then extend a claw into her b hole just for fun, BUT that never happened and I was extremely unsatisfied with the movie because of it." -Macaqueistrong
                    if you are going to be useing your electronics why not hard wire them into your vehicle ? instead of haveing the ugly wire sticking out of your lighter
