problem with cd player
    My cd played keeps on blippin in and out before it even gets a chance to play anything . It turns on then turns off then over and over what could be goin on?????
    What kind of cd player do you own? I had similar problems with my old alpine.
    Midwest car club
    Current rides:
    91 accord lx (5spd)
    92 accord lx (5spd)
    93 accord lx (auto )
      pioneer
        sounds like your shit is real real cold. Mine does that in the winter, but only if the car has been sitting for a while. Other than that, you might wanna check your 12 volt constant to make sure the connection is fitted properly and not loose.
        "you know what a neo-conservative is...it's someone who watches the matrix and believes it's real" - lewis black.
        ohio cb7's #9
          sounds like the ground has come off
          FA1
          355
            did u just install it or was it working fine before?
            did u solder all the wires or at least secure them?
            usually that would mean something is loose
            Retro!
            Hater
              check wiring , one of em must be bad.
                i have a brand new panosonic with a subout if u want for 100 shipped
                (\__/)
                (O.o )
                (> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination!
                  x2
                  YouTube Clicky!!
                    It's most likely the ground, I had the same problem with my pioneer deck and I took it to best buy cause it was under warranty and it was just the ground and I felt stupid as hell cause I coulda fixed that myself without having to set an appointment and driving 30 mins just to wait even longer
                    P.S. Screw Best Buy's stupid audio team
                      yea there idiots there...i worked at future shop (canadas best buy) and i told the audio guys wat to do they were soo dumb....sorry for off topic
                      Burrito Bandidos: It will change your fuckin life
                        which model do you have? I have one of the dual face ones, and whenever the face gets to full extention, my cd player shuts off and closes, and keeps repeating that cycle. I temporarly solved the problem by keeping the face shut, but i lose all features of the unit. I think it has something to do with the wire that connects the second face, I've heard many pioneers, even the single face ones having the same problem. Thier wires just go bad and you need to get new ones.
                        --JDM F22A--
                        JDM schmeDM, these lights are DIY-DM.
                          I had a similar problem with an alpine single face, but sometimes what happens is, since the face was motorized everytime I switched CDs and the face kept folding out it became loosely detached from the CD player, all I had to do to fix it was detach the face and put it back on, it happens every so often.
                            Sounds like you were the stupid one and they fix the problem
                              Ouch...well you gotta understand, when someone installs something for you it shouldnt mess up within a day or two, when stuff like that happens there's really only two fair assumptions, faulty product or bad installations, I just took the safe way and assumed both.
