Front speakerwire shorted?
    ok so im driving to school, system blaring..i take a sharp turn and my speakers go nuts..they sounded like they were blown and just plain nasty..well i quickly shut it off and went to class, when i got out i checked my amp ground and it was a bit loose so i fixed that..
    Now all my speakers sound good except for the front passenger side..i checked the connection and it seems fine so i swapped speakers and it still sounds horrible...im thinkin maybe its the speaker wire is messed up?? any suggestions?? i need to fix this asap
    Click ^^^ for MR Thread
    Originally posted by steelbluesleepR
    by the way, arguing on the net is like womens basketball, even if you win, no one cares.
    stock speakers?
    stock headunit?
    has anything been messed with lately?
    I see you said you have an amp, did you change anything lately, add any components?
      Speaker wire connected properly? Also check the connection for the speaker into the back of your headunit, if you have a headunit.
      Coming soon....
        sorry...im running a panasonci HU, Xplod 6.5 and LA 6.5....i attached some tweeters to the front speakers a while ago...my amp is only connected to my pair of 10s..never had a problem b4..all connections were crimped and i put electrical tape around em to be sure..
          get a dmm and test it
            ok..well today i checked out EVERY part of my system to make sure everything was good...come to find out the problem was coming from my HU very aggravating...i connected my speaker directly to the output of the HU and got the staticy, raspy sound...is there a way to fix this?? or do i just need a new HU
