try connecting a 9volt battery to the rear speaker connects in the back of deck if you hear a buzzing then the deck is bad. If not then check the + - ends and see if they are right, if they are then maybe the raer speaker wire is cut or possible stripped
Yeah its the deck it went bad! I tried to hook up a Bass Bazooka without A Converter and fried the rear channels time to install the S2000 CD player again
