HELP coupe power locks
    ok so yesterday i tried to do the shave door DIY and it tourn out prety good but i raned into a problem. the little motor to lock the passanger side doesnt lock all the way it does lock but you have to do it several times. does anybody know what the problem might be? do i need to get a new power motor lock? and will the sedan ones fit? or only coupe? becuase my car is a coupe i dont know what to do i took the mottor out becase i took the key locks stick that goes to the motor because the lady o bought it from got jacked like that so i just decided to take them out please help i need the car and i dont want to leave it like that
    that happend to me also yesterday my door locks where not working so you had to push the button like 10 times then it will work ,its not the shaved handles its becasue of rain from the window going down and water dripping in the inside or water dripping from the stripping. take the door panal off,take the box out and clean it out dry it there will be some moisture in side and any little sador points that are burnt re sador them and clean the board a little also making sure everthing is clear of any moisture,it took me 10 min total depending on how many times u took that door panel off but it is very easy,but u dont have to take the hole panel off liet it hang a little from the power window wiring
    (\__/)
    (O.o )
    (> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination!
      well my dad whent to the junkyard today to see if he can find the motor but ill try to clean it up and see what happends the drivers side works hella fine but is just the passengers side it might have a little bit of rust like you said because of the rain and all the rust ect ect.
        I have that same issue on one door and was told its the actuator going up. Yes coupe parts are different than sedan.
        '92 Accord LX Sedan--Bordeaux Red Pearl --OEM--279k Daily Driver
        EX Lip & Alpine OEM single CD Player. No more useless pocket!
          its the door lock module for sure
          (\__/)
          (O.o )
            found the problem and its fixed it was the little motors of the locks you can fix this by just swaping them from one from the junk yard. thier the same just swap the little motor and thats it alot cheaper if you have problems witht he coupe door locks sendas you can just replace the whole thing
