Clean Job
    Clean Job
    so my 91 EXR got broken into , they did such a clean job it took me a day before i fully relized my sub and amp were gone and my car had actually been penetrated.
    basically one morning i get in my car everything seems normal, except my cd's were gone, and i'm just like "hrm i musta been drunk and put them in the house or soemthing" then i wondered where my cd's had gone all day. then the next day i come out look in my trunk and relized in fact my car had actually been broken into . they didn't scratch, break or mess up anything, it was such a clean job, i think the car was locked still even. luckily my amp and sub were pretty crappy, but i miss those cd-R's and cd's, i spent hours making them.
    i guess i gotta start figureing better ways to protect my CB7 cuz my luck finally ran out.
    ~~~~~~~~~~1991 ExR alb F22a6~~~~~~~~~~
    alarm?
      Responder Systems from Viper are simply the most advanced 2-Way Security and Remote Start systems in the world! The interactive display on the Responder remote confirms all commands - virtually instantly - with easy to understand icons, plus text! It alerts users to security system triggers by beeping or vibrating when out of audible range of the siren. And of course the 791XV and 591XV will start your vehicle with the push of a button, and you'll get confirmation back that it started, from up to one-half mile away! (depending on conditions)
      Viper 791XV (p/n 564V) MSRP $599.99
      2-Way Security System / Remote Start System with Responder Technology
      * 6 channel remote start/security/keyless entry system
      * Confirms commands and system triggers on the transceiver LCD screen
      * Clone-Safe® Code-Hopping®
      * Parking Light Flash
      * Failsafe® Starter Kill
      * Anti-Grind
      * Stinger® DoubleGuard® Shock Sensor
      * Revenger® Six-Tone Siren
      * Bright Blue LED Status Indicator
      * Miniature XCRS (Extreme Capacity Relay Satellite)
      * Defroster Output
      * Built-in Turbo Timer
      * 3 Auxiliary outputs
      * Dome Light Supervision
      * Comfort Closure
      * 4 Auxiliary Outputs
      * Horn Honk
      * Includes One 2-way Responder Transceiver
        Park it close to you as possible and check on it once in a while.
          791 thats what i have. and i have a 771 too on another car.
            add a motion sensor.. they do not come with the alarm. u gotta buy it extra.. and when u get ur alarm install. request a hood pin install with it too. it should b free it comes with the alarm but installer tend to not install it since they gotta make a whole and run a wire in the firewall and all that when they just wanna hurry up and finish ur car and get it outta the shop. request a hoodpin install, and motion sensor, not such a bad idea to also get a audio sensor. for those who like to crack the back pocket windows. but on honda they tend to pry the driver or passenger side window out and slide their arm in and unlock the door. motion sensor will trigger.. but just to be on the safe side. i say remove the pin on the door to unlock and lock. and unplug the power lock,unlock. so the only way that door is opening is with the remote control. dont bother lockin ur trunk. i pull that hard and the trunk open no matter what. but be creative.. take the cable out and make it short sumwhere. then hide it under the seat so all u gotta do is pull the metal wire and the trunk open. it's better.
            DEFJAM
            MY RIDE ON CB7 DEFJAM on 93
              I have a proximity sensor as well, it wass annoying as hell. I had to rewire a little something to get it to my likings
                do you even know how they got in?
                  i like it when if u get close the alarm goes off even when u didnt even touch the car or barely could look inside.. i plug in the motion sensor at night so there's no reason for any human being to be any close to my car since it wayyy in the front block by my parent, and my brother's car. i'm tryin to get a lil sticker say "tamper with the vehicle and u will b shot.
                  DEFJAM
