Is there anyway to hook up a backup battery to an alarm system that doesnt have one? What type of battery is it and whats the best way to hook up one of those high decibal sirens from an auto parts store or alarm retailer?
Alarm backup battery
backup battery sirens blow ass you need dei part number 520t. easy to install i have it on mine
edit: actually if you want to use the back up battery siren hide it in the interior somewhere, not just under the hood as thats easy to cut.Last edited by 2.2litrebeater; 10-19-2006, 08:33 PM.FA1
355
I dont have a dei system, so would it still be a useful plug and play since I have a non-dei alarm?Originally posted by 2.2litrebeaterbackup battery sirens blow ass you need dei part number 520t. easy to install i have it on mine
edit: actually if you want to use the back up battery siren hide it in the interior somewhere, not just under the hood as thats easy to cut.Last edited by JTEK24; 10-20-2006, 10:26 AM.
not if they disconnect the power wire leading from the back up battery to the alarm. the backup battery works if they cut the 12v feed to the backup battery or disconnect the vehicles battery.Originally posted by jtek24what about if they disconnect the alarm, it should still go off right?FA1
355
So whats the point of having it if that happens? Is that just a risk you take or have a backup battery for the backup just in case.Originally posted by 2.2litrebeaternot if they disconnect the power wire leading from the back up battery to the alarm. the backup battery works if they cut the 12v feed to the backup battery or disconnect the vehicles battery.
well for 1 without a backup battery all a theif would need to do is pop your hood, thers a vido maple made showing how easy it is to get to the hood cable through the wheel well, and disconnect your battery. then your alarm is pretty much useless as they can steal your stuff or buy some extra time to bypass your starter kill. also since most alarms are installed somewhere under the driverside dash all they would have to do is look under real quick ans snip the 12v wire coming from the ignition harness. with a backup battery they will need to find it to kill power.FA1
355
