i have a 90lx and wondered if a 98-00 civic si or 00-04 odeyssy oem deck work on my accord? will i need to by a converter or something? has anyone done it yet? thanks
98-00 civic si deck!!!
yes it can be done easily...if you look at both types of harness they both have 13 wires coming out of it. those wires are all the same so you can just color match it. you would need a basic 20 pin harness that goes into our stock radio harness then you need the reverse 13 pin harness which is what you plug directly into the unit. then just crimp all 13 wires plug both of ends of the harness in and your set.Last edited by Blk EX Coupe; 05-25-2004, 09:38 PM.
Originally posted by 90accordlxcb7
i heard that a 98 civic (im not sure if its si or not) has the same connection as our accords and early model hondas. is this true?
98+ uses a different harness then ours pretty much everything before 97 and older will work with no problems other then the code...
Re: 98-00 civic si deck!!!
what's wrong with your current radio? or do you want a OEM CD player?Originally posted by 90accordlxcb7
