I was just wondering if anybody had done this before. I think it'd be a neat custom addition to my car, but I have no idea where to start. Ideas / Examples welcomed.
How to set up a battery voltage meter
here's a start. i mounted a digital voltmeter in the other spare button on the dash by removing the plastic cover, putting the meter in and then double side taped it to a piece of smoked plexiglass/arcylic. see the 11.5 figure..? it's there. i wired it up from a rear power source, tapped one of my head unit wires. ground to body, screwed it down. easy
i got the voltmeter from a battery distribution block commonly used for audio setups. try getting a small one.
my post wasnt actually directed at you but rather the other people who already have hooked up voltmeters
your battery will hardly ever display 12v, it jumps around all over the place and stays above 12v for the most part
personally, i want a voltmeter so i can monitor my batterys condition since im running a computer in my car
its really only relevant if youre having battery problems or if youre running high powered aftermarket equipment93 Accord LXA AT
I bought a Stinger Digital volt meter. The way it I wired it up is, I had the constant go straight to the battery, and the grounds, wired together and go to a ground. The last 2 wires are the Remote and the dimmer. The remote is fused to the ignition (only works when car is on) and the dimmer wire goes to the dimmer switch for the gauges.
Disregard females, acquire currency.
My 2003 Nissan Maxima Members Ride Thread
DIY: HOW TO POST PIC(S)
