PT sway bar install
    PT sway bar install
    So you need the EX rear crossmember AND you have to drill into the subframe?
    Does anyone have pics of where to drill?
    Whats the going price on a rear EX crossmember?
    thanks
    My Car
    FREE Web hosting solutions
    whats the pt bar? i thought the issues were between the st(suspension techniques) or progress?
    Either way the ST bar bolts right up i believe.
    I have the progress bar and you only have to drill into the lips of the crossmember not directly into the crossmember itself. Its not hard to do man. If I could figure it out so can you.
    Edit: You do not need the EX crossmember
      im guessing PT = Progress Technology
      i have an LX and the progress bar is meant to be installed on ANY model, regardless of subframe. whether you have a DX, EX, or LX, you will still need to drill 4 holes into the subframe to mount the progress bar to the chassis
        Ok, good to know. Is there any method to making sure you're in the right spot before drilling?
        My Car
          There's no real right or wrong spot. The lip of the crossmember extends far enough for you to drill into in a small area of the whole piece. Meaning you couldnt put the bracket in the middle of the crossmember because the lip of it doesnt extend out far enough...... When you get it along with the instructions it'll be pretty self explanatory to figure out what you have to do.
            Sweet. Thanks for the info.
            How often do you hear a rattle between the exhaust and that sway bar?
            My Car
              Almost 24/7 only noticeable on idle really but its always rattling. But everybodys exhaust is mounted different so yours may or may not rattle.
                i heard some of that heat wrap tape could pad it a bit to reduce the noise, what do you think?
                My Car
                  it would help to reduce the noise, yes
                    Lol yeah it'll probably make it go thump thump rather than tink tink tink. But i suppose it would be better.
                      another question:
                      I just looked at this bar. I thought I was ment to get a plate with it? Like:
                      ... or is that for a different car... I'm not sure
                      Either way, i just wanted to make sure that I dont need this extra plate.
                      Now that I look at other pics it seems that the above pic is a different bar for a different car.
                      Where is the point of contact between bar and exhaust pipe?
                      My Car
                        http://www.cb7tuner.com/vbb/showthread.php?t=92082
                        ----------------My 92 Honda Accord LX---------------------- My 97 Nissan 240sx LE----
                        NE GUYS, Buy the last of my accord parts
