i just used a thick manila folder(traced FITV, cut, and place between FITV & manifold) and it's worked flawlessly since b4 i even did the swap
fast idle thermo valve
My Ride thread
Flickr
Originally posted by d112crzyAnd it can only get better. That's the best part.
All I gotta really say is:
Now that I think about it, removing the coolant lines/blocking the FITV off might provide some gains.
My reasoning is that the coolants heat is transfered to the throttle body, which in turn heats up the air entering the throttle body, to an extent of course. It's not enough to feel, but I'm sure it does lower intake air temps just a bit.
**just rambling random shit that popped into my head.
I doubt it would heat the air that much.
I've placed a restrictor plate on my IACV and I now have LOW cold start idle...like it will damn near die.
Without the restrictor plate the cold idle is still a little low...hmmm I guess my FITV might be messed up.
once the car is warmed up it idles right.
I'm still fabbing that restrictor plate btw...hope to get the bugs worked out...once I actually do more work on it that is.____
I blocked mine off just the other day due to idle problems after my h23 intake install. Autozone sells a nice roll of rubber gasket for about 6 bucks. Just cut it to fit your application and block off whatever you want. Worked out fantastic for me. I was also able to trace out other gaskets and cut them out with a razor blade, Saved a ton of money it just takes a steady hand and some time.
i tried rubber myself and thankfully something made me wanna check things over and found out the damn thing was just about to rip right through ...
and about blocking the IACV... i don't really recommend it since it's not even a main common failure(at least as much FITV) i personally tried it myself and the car would B-A-R-E-L-Y idle, had to take it right back off...
My Ride thread
Flickr
Originally posted by bcjammerxI've placed a restrictor plate on my IACV and I now have LOW cold start idle...like it will damn near die.
If the FITV isn't working, then the IACV should kick in to lift the cold idle to the correct warm idle speed, though with a restrictor it's ability to do so will be less than without the restrictor. How large is the hole in the restrictor?
With both the FITV and the IACV blanked off on my f22A9 engine, I have warm idle set at 800, and cold idle is around about 400ish. Even at this rpm the idle is fairly stable and relatively smooth (i.e. only a bit rough), but only after I fitted new spark plugs. At any rate I just push the throttle pedal a little to keep the cold idle up a bit until I get underway (about 5 seconds and I'm off), and it doesn't take very long for the idle to rise and smooth right out (though it isn't exactly snowing around here).Regards from Oz,
John.
Originally posted by DRzCB72nru still need warm air going into the combustion chamber so that it helps evaporate the fuel. isnt that why theres coolant lines in the TB? or am i wrong
The amount of heat that the intake air will pick up from these components will I think be very small (particularly from the IACV and FITV), and have little if any noticable affect on intake air temp (general heating of the plenum / manifold from heat soak and ambient engine bay temp will be far greater).
For maximum performance you generally want the coolest intake air temps you can reasonably get, unless the engine is carburetted with a poor manifold design (in which case you need a heated manifold to adequately atomise the fuel and prevent it from 'wetting' the cool manifold walls). Fuel exiting an injector at very high psi (compared with the pressure differential in the carby venturi relative atmospheric) through a tiny orifice will be very well atomised, and not in significant contact with cold manifolding since the injectors are so close to the (heated) ports.Regards from Oz,
John.
Originally posted by prNonVtec4ui tried rubber myself and thankfully something made me wanna check things over and found out the damn thing was just about to rip right through ...
Originally posted by prNonVtec4uand about blocking the IACV... i don't really recommend it since it's not even a main common failure(at least as much FITV) i personally tried it myself and the car would B-A-R-E-L-Y idle, had to take it right back off...
Even when the IACV is working as Honda intended, it creates problems with gear shifting (more or less irrelevant for automatic cars). It would be OK if all it did was adjust idle for auxilliary load, but it does other things that are a pain in the arse.
I am willing to contemplate that the problems I've had with my IACV (related to gear shifting) could be due to the IACV not working entirely correctly, but I doubt it because it it did everything it was supposed to do with idle compensation perfectly. I've also driven a manual Civic that suffered the same reluctance to drop rpm when shifting gears.Regards from Oz,
John.
I was starting with small holes and was going to work my way up. I was also going to look into only increasing one holes size...again...more reasons why I haven't fiddled with it.
...I think they are right now set at 1/16 of an inch on both holes HA HA super small!!!
I was at 1/8 and it didn't do anything to the idle at all.
Sine the holes are so small I figure the IACV may be trying to compensate but really can't, also I figured this would sorta render it useless...but it does idle right when warm and it doesn't drop the rpms between shifts like it does when the IACV is unplugged. Also, when in gear and rolling...light throttle changes do not jar the car around as it woud when I unplugged the IACV...so it's doing something.
Currently it is ideling up to 1100-1200 now that is is super cold...but this has only been the past two days...when it snowed and iced. Normally it will try to die then kick up to 400-600 then back down...etc. If I leave the throttle alone it will usually try to idle VERY low...maybe 300-400...to low for me, I worry about oil pressure...but it's when I come to a stop...it dips down to 0 then kicks up...repeats. BUt...usually it behaves once it's warm...I'de say it behaves when warm mostly...90% of the time.
I am going to alter the block plate some more before I attempt to diagnose that since...it idles just fine without the plate.____
Originally posted by bcjammerxI was starting with small holes and was going to work my way up. I was also going to look into only increasing one holes size...again...more reasons why I haven't fiddled with it.
At any rate, 1/16" is probably too small to allow proper idle speed compensation (especially with two holes that size through which the air has to pass). On my CB7 the single small hole (when I was using a restrcitor plate) was 3.5mm (a bit over 1/8"). You're probably as close to damnit to having the IACV completely blanked off.
Originally posted by bcjammerxI was at 1/8 and it didn't do anything to the idle at all.
Originally posted by bcjammerxSine the holes are so small I figure the IACV may be trying to compensate but really can't, also I figured this would sorta render it useless...but it does idle right when warm
Originally posted by bcjammerxand it doesn't drop the rpms between shifts like it does when the IACV is unplugged.
Originally posted by bcjammerxAlso, when in gear and rolling...light throttle changes do not jar the car around as it woud when I unplugged the IACV...so it's doing something.
Originally posted by bcjammerxCurrently it is ideling up to 1100-1200 now that is is super cold...but this has only been the past two days...when it snowed and iced. Normally it will try to die then kick up to 400-600 then back down...etc. If I leave the throttle alone it will usually try to idle VERY low...maybe 300-400...to low for me, I worry about oil pressure...but it's when I come to a stop...it dips down to 0 then kicks up...repeats. BUt...usually it behaves once it's warm...I'de say it behaves when warm mostly...90% of the time.
Low oil presure at very low idle isn't a problem. So long as you have oil flow you're OK. I wouldn't be concerned unless the OP idiot light comes on at low idle.
Originally posted by bcjammerxI am going to alter the block plate some more before I attempt to diagnose that since...it idles just fine without the plate.
If you blank the FITV as well as the IACV you will have a very low cold idle (which may or may not be a real problem for you, I don't find it to be a problem for me), but if you keep the FITV operable and ensure that it's good then it should anly affect cold idle, i.e. rasing it for the first few minutes of operation, which sounds like it would suit you better.Regards from Oz,
John.
