engine running bad
    my ecu is a p13.i think its the ecu from a 92-96 prelude?
      can anyone confirm this?thanks for the help
      i will do a compression test to chek if my valves ajustement is good.any other idea?
        i've done a compression test...i have 60-70-65-90
        i've reajusted the valves and now i have 90-90-90-90.
        but the engine is still running like s**t...on 2 cilinders
        i will chek if my injector sprays corectly.
        anyone have an idea whats the problem?
          when you changed the headgasket did you check the valves to see if any of them where burnt
          Please, Leave me some feeedback on my ride ^CLICK ^CLICK ^CLICK
          Originally posted by deevergote.
          But Honda guys know EVERYTHING about EVERYTHING! If you don't believe that, then you're just wrong...
            i have new ferrea racing valve in it.
            i tested my pressure gage at school 2day and it wasnt good.i barrow one from school and i will try it after super.
              i have 200 psi of compression on 4 cilinders
              i will chek the timing this afternoon
                the cb7 is going to the garage...
