Brake swap..
    Brake swap..
    i need to change my brakes now, and thought that since i am going to do a h22 swap when the winter comes again, can i just shange the brakes to 2.2vtec brakes now..
    so, can anyone help me find some one? link?
    what do i need for the swap from f22 brakes to h22 brakes?
    -91 Honda Accord 2.2i 16v 150 hk (newly repainted;D)
    -91 Honda Accord 2.0i 16v 136 hk(Crashed)
    My car here!
    CLub Honda Norway: www.club-honda.org
    I suggest you also do a ROH swap. Not sure if TASauto shipps to europe, but they have the best deal right now. For the brakes you need just the VTEC calipers and 282MM rotors.
    wat?
      ROH swap? what means that?:P
      My car here!
        wat?
          someone know where to buy what i need?
          My car here!
            Idk, I did the Vigor swap, about 200+ dollars less than the VTEC swap. Uses the same calipers, pads and same size rotors, but retains the Hub over Rotor brake setup, big deal. You won't be doing brakes every month, so I figured it was worth it. All you need are:
            -Vigor/Prelude VTEC calipers (they're the same)...got them remanufactured locally after trading in the JY cores to save $$, about 115 for the new reman. ones and 40 for the cores.
            -a Set of Pads, I went w/ HAWK HPS, again the same since the calipers are identical.....around $78 at my local Pep Boys
            -But you need Vigor Front brake rotors, since its like the CB7s H.O.R. style I got these for 40 a piece + shipping so around 100 shipped off import replacement parts I got the Brembo Blanks and am LOVING them, they stop really smooth and are very high quality.
            And you dont have to but I would recommend a set of Stainless Steel lines to take advantage of the better stopping power. You'll also brake in a shorter distance and w/ more force since the lines dont flex at all. Got mine from a Vendor on Hondatech.com for 85 shipped for disc/drum and 105 shipped for disc/disc w/ ABS.
            That's my spiel on it....
            oh crap, you're from Norway....hmmmm
