willl GSR cams work??
    will the GSR cams work with our motor or what not???
    ^sold
    Eeh...GSR has dual cams and it wouldn't work on our single cam F22s. If you're talking H22/H23, F20b, F20a ,etc I dunno.
      Most likely not, GSR's rev much higher than we do, and the cam profile controls how long the valves will lift and stay open. The block and the ecu would probably be like wtf
        No they wouldnt. Too different.
        Why does everybody thing GSR's are so great? They dont make any torque, and are actually pretty slow.
          GSR <<<< way over rated.
              Dont know how much this will help, but:
              According to AEM,
              B18B & H23 =same
              B16, B18, & H22A = same
              again this is according to AEM instructions on cam gears.
              Jay
              Hittin Switches - Draggin XhaustAlways Under Construction
                That's for cam gears tho, not cams.
                Edit:
                B series engines have an 81mm bore, H series has an 87mm bore... the bore spacing is going to be different, meaning H series cams are physically LONGER than B series cams.
                -Ryan-
                My life is rated R.
