hot/cold gauge
    hot/cold gauge
    Ok i have a cb7 sedan and a few months ago my fan stopped working like it will cut on sometimes when i cut the car off but if i just let the car run for about 30 mins it runs hot...and then the other day i took my dash aloose to install some leds on my gauges and when i put it back togather my hot and cold coolant temp guage doesnt move at all?....does anyone else have these problems....?????
    Check your needles, perhaps they're pushed on too tight, misaligned
      the needles...
      The needles are permanently attached if you removed them you lose...
      They cannot be mis aligned unless you changed something on the inductor that moves them (i.e. added more wire or took some off).
      Did you remove the gages from the cluster (removed the three brass screws that attach them to the circuit)?
      If you did my guess is that you over tightened one or all of the screws on the temperature gage. This completely messes up the gage, and as far as I can tell is un-fixable. (I am working on one that had this issue now)
      My next question is what is the make of your cluster. (yes they have different makes)
      Is it seiko or denzo (to find out look below the speedo and find ether an NS or an ND) NS = seiko, ND = denzo
      I had my issue with a seiko, so if yours is too then maybe they are just not happy after removed
      If you have any other questions of information post it up there seems to be a few people having the temp gage issues.
      201 Whp H22a with bolt ons, see the progress from stock f22a to now HERE
