1.Iv started to slowly tear apart my H, so I can start the rebuld. As soon as I inspect the pistons to see if they need to be replaced or not. I will be getting a rebuild kit.
I was looking this site http://www.importperformanceparts.ne...FQWxsgodxjGWrQ
If my pistons are bad I will get the Master rebuild kit, if not I will get just the re-ring kit. Whitch includes everything as the master kit except timing belt, pistons, and expansion plugs. Whitch ever one I get I will upgrade to the TOGA HP Rod and Main Bearings.
Does this all sound good, is the company reputable?
2.First off Im going to have the head and block resurfaced. Then since im going to have everything torn apart is there anything else I should be doing?
I plan on using my F22 manual tensioner to do the timing belt conversion. I was thinking of getting a balance shaft removal kit as well, but what are there intended purpose and how would it benefit me?
I dont have a huge budgeet so im nott looking to do any major machine work. Although I do plan on running a 100 shot direct port a little while down the road...
I am open to all suggestions, ideas, and comments?
Thanks
Thanks
