Ok guys since school destroyed my original mild build up on the H22. Iv decided to just put the motor in now with the timing belt conversion. But in a month or two I plan on buying a few bolt on parts.
I am looking for those best bang for your buck kind of mods. Like buying a megan or dc sprts header, cutting off the original collector and wlding on a 2 1/2 or even a 3" collector, with a custom 3" catback. I remember this was tested and that the 3" netted more hp than 2 1/2 cat back.
These are the kind of mods im looking for. Or any mods to increase the durablility and reliability of my engine.
:Plans as of now:
-Cheap header cut at collector with 3" pipe welded on and a 3" flex pipe in original location. Continued onto a full 3" cat back.
-Either euro r intake mani? Or Stock with IABS removed.
-Balnce shaft removal kit
-EGR Delete...not until tuned on p28
-3" intake
-Tb Coolant Bypass
-62mm bbk throttle body
-Weapn R throttle rotor
-Polyurethane filled motor mounts
Lets compile all kinds of info on benificial mods for the H22 that are at least benificial...
:Plans as of now:
-3" intake
-Tb Coolant Bypass
