Boosted.. which gauges to get...
    ok so I have a Boost gauge autometer and I have AEM wideband now I got an Oil pressure but is that good or should I get the coolant temp instead.. let me know..,
    Get Both
      Originally posted by MR.PHIL View Post
      Get Both
      naw more then 3 is kinda rediculous in my opinion
        it's all important.
        I <3 G60.
          Get Both
          u asked he answered
          Dont drive faster than your gaurdian angel can fly
            Personally I have Boost, A/F, and Oil.
            These three are very VERY important. You obviously want to monitor your boost levels, and you got the wide band O2 sensor so you want to watch that one too.
            My reason for oil pressure is this. You already have a coolant temp sensor. It works pretty dang well if you ask me. When you see that gauge go up to "H" then you pull over and stop. But if you have periodic oil pressure loss..... You could be up the creek without a paddle.
            I watch my gauge and not only does it tell me I make about 20 psi for every 1000 RPM, but doing 5K RPM, my gauge tops out and the pressure release valve opens and adjusts. IF I were doing 5K RPM and I saw I was only making around 40 psi and the release valve didn't actuate, I know somethings wrong.
            So there you have it. Boost, A/F, and Oil. Good luck
            Been a long time. Still alive...
              my next suggestion would be EGT
                what about oil temp. teamed with a turbo timer
                  No need for a turbo timer.
                  Oil temp...well I'm sure one of the other gauges would show something wrong if you're oil was dangerously hot.
                    curious..why do u say no need for a turbo timer?
                      Because it only takes 30 seconds of you sitting in the car to be fine.
                      That, or just don't get on it when you know you're going to have to turn off your car soon.
                        i got ya
                          what if your running late for work
                            leave 30 seconds earlier
