What do you guys think about the ECU chips they sell for the P13 on ebay? Do you guys really think they are worth the money or would I just be better off buying a V-AFC? I have a h22 and 5 speed with a 75 shot of NO2.
Ebay ECU chips?
Re: Ebay ECU chips?
Well that all depends, Do you know how to install the chip yourself? Would you know how to install the V-AFC yourself? Who will tune it? Is your engine/ecu usdm or jdm?Originally posted by hype8912
USDM P13 and JDM P13 programs are not interchanable. Some of the programs available for the USDM P13 are acutally decent. For the JDM they are not much of an improvement however they do remove the speed limiter and adjust your rev limit and Vtec engagement.
You could also get yourself a P28 and chip that with a program tuned to run the H22A. There's many options for you, I personally would stay away from the V-AFC. Esspecially if you have access to someone that can tune a P28 for your car on the Dyno. That makes all the difference.
I know how to install chips and wiring up a VAFC. The engine is a JDM and JDM ecu. I have access to a guy who does dyno tuning and is a hondata dealer. They charge 125 bucks an hour for wide band motec sensor or 110 for a regular sensor. What do you think the max rev on a stock h22 should be?Last edited by hype8912; 10-24-2003, 12:56 PM.
they're "okay", look at BustedLX's dynos of his H22 from a few weeks ago. Whatever you wind up doing, make sure you get it all tuned on a dyno....
- NathanNathan Morris
92 Accord LX - RIP
92 Civic CX B18B1 Hatch - RIP (126whp, i/h motor)
99 Civic EX Coupe w/ 1.9L stroker on the way, current at 121whp.
nonVTEC.com - Technical discussion for F, D, and H series nonVTEC tuners
H22Power.com
