okay so i have came to the conclution that my h22a was a bad motor to begin with and now im going to rebuild it from nothing. i am wonder what the best products there are to mildly build the motor like what pistons or cams or valves, with out it costing to much money. im hopig to make roughtly 230-250 whp on a N/a motor. any help would be nice. thanks.
h22 dead gonna rebuild with a mild build, wondering what to get.
Red Wagon DD - 1993 EX
http://www.cb7tuner.com/vbb/showthread.php?t=172734
Gray Wagon Project - 1992 LX
http://www.cb7tuner.com/vbb/showthread.php?t=166337Tags: None
You should mention the components that are bad with your motor. This is a starting point, as you have to fix those first before you upgrade anything.
If my assumption is correct, it is bottom end related. I would say if you can locate a stock H22 block for cheap, your head, intake manifold, etc over. Sell the bad block to someone else for parts, get anything you can off it. Use that money for camshafts. If you haven't already, open up your exhaust. Also, hopefully you have an Hseries tranny mated to this and not an Fseries.Last edited by HondaFan81; 11-20-2008, 10:13 AM.
mild and 230whp dont go together either, thats a full build.1990 accord Honda-Challenge, H22 powered
newer race video,older race videos
1991 accord parked, parts and back up shell
1993 accord acquired 6-11-16
okay well i think the block is fine and i do have my old f series tranny to it. i was thinking about putting a 75 or 1000 shot on there. is there any decent aftermarket cranks for the H
I'm selling a extremely cheap h22a bear head in good condition. If your head is shot that is.
I was going to just do type-s pistons and a h23/f22 crank and rods. Something with piston clearance issues with the pistons though...ive been out of it for a while. That be around 230whp. Granted you have good I/H/E and your motor is healthy.Originally posted by deevergote..It's not cheap to build a fast CB7, especially NA. However, if you're willing to put the money into the car, it's well worth it in the end. There ARE faster cars out there, but some people, like me, want THIS particular car to be fast!...
1993 H22A cb7 <3 miss you
04 WRX stg 2 sedan
Current - 02 WRX stg 2 wagon
oops i meant 100. i didn't now the f22/h23 cranks fit. are the stronger than then the h22's.
are the f22 blocks the same as the h22. im gonna use head studs
sweet. wheres a good place to buy types S parts.
Not sure where to get the pistons but heres some F20B cams which are the same as type s cams. http://www.cb7tuner.com/vbb/showthread.php?t=120688
"The Turtle"
DD/Trail Rig/Mud Bug
thanks man ill do some reseachin'
