i was siting at a stop light and it just cut off. i tried to restart it and it kinda started but it shook vilently then died, i trid a jumo box when the battery stated to died and a jump. all it does is turn over it. it has fuel and is geting spark, help me this sucks i dont no what it could be,
my cb died :(
Originally posted by beerman987 View Posti was siting at a stop light and it just cut off. i tried to restart it and it kinda started but it shook vilently then died, i trid a jumo box when the battery stated to died and a jump. all it does is turn over it. it has fuel and is geting spark, help me this sucks i dont no what it could be,
2. it could be a main relay
3. if your car starts up but has no power ex:no headlights,radio,etc....it is more then likley the alternator....this last one is my issue with my coupe
out of these 3,from what i understand,i would say it's the first.....more info if you could,and i could be a little more dead on
if you spray starting fluid into the intake and it starts up, runs for about 1.5 seconds, then dies, its either fuel pump or relay..id change the relay first tho dont do what i did and change my fuel pump only to learn the pump was still good but a bad relay..but when you say its got fuel, are you saying you checked pressure at the rail, or ya just know theres gas in the tank? when my relay went out and i tried starting with starting fluid it would run for a sec, then violently shake while it died..scared the shit outa me..Originally posted by chessboxerWe know these are good cars, but for some reason, all the world wants are freaking civics and tegs. Bleck.
Do you hear the fuel pump prime? If you do, the pump is probably fine.
I'd be more suspicious of an ignition related component. I just had to replace the coil wire on my prelude because it was bad. I got spark and it looked just fine. I got fuel and the timing was fine. I checked the resistance in the ignition wires and the coil had very high resistance. It would allow spark, but a weak one. Replaced it with new and now the car runs great.
Check the ignitor, plug wires, coil, rotor, cap and plugs first. I'll almost be willing to put money on ignition.
