IM delimma
    IM delimma
    I have two h23 IM's. One is off an auto and the other is from a manual. What should I do? what combo would be the best? I have an f22a1 5spd. Please let me know. Thanks.
    91-accord
    watch quick clip: 10-80 mph
    they're both the same except for the trottle rotor(the thing the throttle cable attatches to on the throttle body) so I would just use the one from the manual car. best of luck to ya.
    Finally Up and Running. Numbers to Follow. Check my MR
      but the manual IM doesn't have one. Is it possibly to use the one off of an f22a?
      91-accord
        does the manual i/m have a throttle body on it still, cause thats important, but yes, the
        f22 one can be re-used.
          no.
          91-accord
            if i recall, the f22a TB doesnt fit on the h23 plenum
              Just put your stock F22 throttle rotor on the auto H23 IM since that's the one with the throttle body on it still. Problem solved.
                Yeah that should work, or just go get a manual H23 tb.
                "The Turtle"
                DD/Trail Rig/Mud Bug
                  yup just swap over the throttle rotor
                  My Members Ride Thread
                    WWWOOOOWWWW
                    what a dilemma
                    Just do what PR CB7 said.
                      Originally posted by pr Cb7 View Post
                      wwwoooowwww
                      What A Dilemma
                      Lol
                        Okay so I'll run the manual IM w/ the auto TB w/ the f22a throttle rotor.
                        What about sensors and vacum lines and hose. which ones would have to be pluged and used?
                        91-accord
                          use all the same vacuum lines.
                          #21 goes on top of the TB and the other two go on the backside of the H23 IM
                          Fuel pressure regulator goes on the nipple in the front middle of the plenum, and if you hook the IAB plate up via vacuum, then run that line to the end of the plenum on the right side, opposite end of the TB.
                            Thanks
                            91-accord
                              what about the ecu? would i still run the same one?
                              91-accord
