How much hp can a 91 AT tranny with a tranny cooler handle?
AT tranny question
I think people have done the DSM turbo setup with auto transmissions, using transmission coolers, and I think the average DSM numbers are +/-200whp. All I know is that i read, as long as you dont beat on it at every light you should be ok. Do you have a tranny cooler? Who is it made by?
1992 Honda Accord Coupe LX
Originally posted by Corban Dallas View PostThe car is getting a h22 next week and I was thinking "why not a turbo too?" Turboed h22 wagon ftw. I dont have the tranny cooler yet but probably a B&M.
what's the current condition of your trans? how often have you changed the fluid? if you go out to your car right NOW, and pull the tranny dipstick, what color would your fluid be?
THEN: 1993 Accord 10th Ann. Ed.---------------------- NOW: 1996 Accord EX
My Ride thread
Flickr
Originally posted by d112crzyAnd it can only get better. That's the best part.
All I gotta really say is:
People of cb7tuner, this AUTO is NOT a joke. It has impressed ME, the hater of auto's.
what fluid is being ran in it?
My Ride thread
Flickr
if you do turbo, i would recommend getting an intermediate shaft as well. I've got a NA H22 and I literally snapped my axle....so my next upgrade is to get an intermediate shaft on the driver's side to beef up the drivetrain a bit better.
you're snapping axle incident was from what's considered "stupidity". not to be rude in ANY way man.
keep running honda atf. Nothing works any better, period.
My Ride thread
Flickr
Originally posted by prNonVtec4u View Postkeep running honda atf. Nothing works any better, period.
speaking for myself and my 2 other auto turbo h22 friends, you might get different result since we don't floor at at every stop light. My stock jdm h22auto tranny with lsd is handling over 300+whp at high boost 13psi. I usually hit 8psi as daily driver to work and to home. if your auto h22 tranny with or without LSD is in good health, around 250whp should be ok since all 2 of my friend does not have LSD and pushing 267+whp on stock engine/tranny
Another notes everyone know Auto Trany make less hp/tq then manual, specially the TQ. so we don't break axle much during launch or race or at racetrack vs manual who spin wheel more. This is just a refference to go by-not extensive tested. With regular fluid change, aftermarket tranny cooler and dont ever do neutral drop, if your turbo setup is good and not half-baked at low boost the tranny will out live your engine.
Most turbo improperly tune and setup will have a dead engine in 3-6months, some will die less then 3 week , has happened to my self and my 2 friend- whom has went the cheap/butt-tune way when we were noobs.
GL and hope to see another boost AUto H22 soon90 Accord Coupe LX, Stock JDM H22A Engine 10.6:1 - Stock Automatic LSD MPA1 Trans, JDM P13 Auto ECU + JDM P19 TCU. Tune with Greddy E-Manage Ultimate
< 317WHP/227WTQ@11psi> B/W S256 turbo, Daily Driving on 93 pump gas - since 2006. Driving Turbocharged CB7 Accord since 2002.
blazen accord: for your trans cooler installation, did you bypass the stock radiator cooler and run only the aftermarket? or both inline? pix would be awesome .
Thnx!
My Ride thread
Flickr
Thanks for all of the advice guys. I will be running Honda ATF in it. How often should I change it with the turbo setup? I won't be doing any neutral drops or flooring it all the time. I only plan to run about 6-8 pounds. Also once the turbo is in I am taking it to a buddy of mine to get dyno tuned. And this guy knows his stuff. He has a 78 ford f350 converted to a dualie, with 22" semi truck wheels(lathed from 22.5) on AT type tires that runs low 13's and high 12's LOL. I will keep you guys posted. At the very least the motor is going in on Monday(along with a new front bumper, cd5 lip, oem fogs, aem 14" rotors, intake, header, high flow cat and some tie bars). I am stoked
every other oil change
ps. might sound overkill, but i'm pretty anal bout my trans
My Ride thread
Flickr
